Water temperature sensor location
4.3K views 6 replies 5 participants last post by  75gmck25
I just bought a 1950 Chevy truck with a SBC 350 engine. The temperature gauge sensor is in the intake manifold near the front. I want to install an electric fan with thermostat control. Should I move the temperature gauge sensor? If so where should it be installed?
The sending unit for my dash gauge was in the driver’s side head, so when I had a mechanical temp gauge I tried both the passenger side head and the fitting in the intake manifold. There was minimal difference in the temp measurement between locations.
To get the block plug out I first cleaned out the fitting and then used a hammer to drive in a hex/Allen wrench and make sure it was seated. Then I continued to push the bit in, and used another wrench to turn the Allen wrench and get leverage.
Bruce
